In the Rhino 6 wip the fillet works better, but it would be interesting to handle two equally valid and correct solutions (see example).
Solution A (fillet correct) and solution B (the fillet extends to the other surface. Unfortunately, Rhino does not run correctly).
It would be a good idea to have the two solutions as option?
What do you think? Would this be possible?
I want the developer to say something (Chuk)
Hi Davide - this seems like a perfectly valid option to have. Both are possible, the choice is more a matter of interface than the capability of the tool.
https://mcneel.myjetbrains.com/youtrack/issue/RH-39232
