Rhino 6 WIP problem access (resolved)
After a few weeks of not using Rhino 6 wip I updated but I can’t log in.
-Simon
I think you may just need to go to your Rhino account (accounts.rhino3d.com) and log in again…
Already tried without success. Also if I click on the login attempt window, Rhino tries to access infinity and I have to close it with ⌘Q.
-Simon
What happens? You mean you cannot access your Rhino account via the web page at all?
There was certainly a problem but I managed to solve it. I bring it back because it could be used by someone. If you look at the photo above, note that there are 4 windows (in addition to the main one). The windows open in succession and I could only click on the penultimate one (which with the red triangle and exclamation point) Now I have solved this. After a few attempts I memorized the place where the window asking for access was opened (yes no). I then tried to open Rhino and walked around on a “Yes” a bit Rhino opened the login page on Safari and logged in. I mean … you have to be faster than Rhino …
-Simon
It looks like you tried to do all that from inside Rhino. What I was suggesting is to re-login to your Rhino account directly via your browser (Safari) and the McNeel web page accounts.rhino3d.com. Generally that fixes the problem.
Forgive me if I couldn’t make myself understood. I had already tried to do as you say but it didn’t work. Login with Safari worked perfectly, but opening Rhino WIP showed those windows you see.
