Just loaded Rhino 6 WIP . Fonction “Trim with region” doesn`t separated the partial element to Ci and Co, all part in Ci.
Hi Giulio,
Using version dated 22/11/2016 16:34,I have still the same problem.
Other thing, I cannot remove the grid from the view using “Document
properties”.
Regards
Hugues
WITH TYPICAL EXEMPLE
Hi Giulio,
properties”.
Regards
Hugues
Please attach the definition next time! I will try to reproduce now…
Hi @Hugues
I should have fixed this error for Grasshopper. We are still dealing with a similar class of problems that surfaced in RhinoCommon. Thanks for reporting this!
I cannot reproduce this other error. Is it now fixed? Or can you tell me the exact steps?
Hi Giulio,
Thanks, Trimm is OK.
Still, I cannot remove the grid from the views.
Hugues
Hi @Hugues
We think we fixed this issue in this week’s WIP. Can you check if you also can no longer reproduce the issue with the grid?
Thanks a lot!
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi Giulio,
For me the grid issue was already solved 2 weeks ago.
Recently I had no major issue out of a crash when a dimension became null
by moving his control point.
I do have, sometime, an error message when closing my file but without any
issue.
All the best
Hugues
Hi Giulio,
That’s the next one :
Asking for a round hole with a pointy tip, the result is a flat tip.
All the best
Hugues
Hi @Hugues
I just tried this, assuming this was the result of the _RoundHole command (right?)
If that is the case, I cannot reproduce this:
Could you send the model and a description of how to reproduce it?
Also, it would help if you started a new conversation about this next time. You can @-mention me if you want to make sure that I will answer.
Thanks!
Giulio
Giulio Piacentino
giulio@mcneel.com
