Rhino 6 WIP crash
Hi all,
I have installed Rhino 6 WIP.
Everything runned normally, from installation until running the application for the first time.
However, after closing and reopening it, it crashed completely, and my computer with that… It was impossible to type ctrl-alt-del to cancel the program.
So I reinstalled the whole WIP, tried again… exact same problem. I could open Rhino once but then impossible to restart the application without crashing everything.
Do you have any idea of what could be the problem?
Best,
Paul
Edit1: It is impossible to see any error message.
Edit2: It always crashes when Rhino loads the Displacement plug-in.
Any hints on this?
Don’t know what is wrong with my setup. I reinstalled the WIP already 3 times…
Does it run fine in Safe Mode?
If so, you could try to disable the displacement plug-in and see if anything else crashes the WIP.
Do you have up-to-date GPU drivers?
