I have a 500mB model that has run at “reasonable” speed in Rhino 5 (once its loaded) but now is crawling to a slower and slower speed in Rhino 6. All I see at every move is A rotating blue donut and its driving me nuts !!
Is there a set of optimal settiings for Quaqro P4000 to get this version runing quicker and are there setgins in Rhino itself that I should consider to get this running faster.
Normally on architecture buildings that are good size it is the shadow casting that will slow things down. There is no question Rhino 6 pushes the graphics cards harder. There are a number of settings we can change to help the transition.
I would look at the standard upgrades first:
Nvidia Driver. Newest one for your card is from October of 2018.
Rhino 6.10 is a good update to get. You can go to the Help pulldown > Check for updates and turn up the frequency to Release candidate.
Apologies for not getting back to you sooner but I have been snowed under this past week.
Many thanks for your suggestions.
I will try these today and let you know how it goes.
In device manager only the NVidia Quattro P4000 shows under display adapters so I assume there is no Intel HD present or it has been disabled in the BIOS ?
There are no textures (as such) the model is mainly glass, metal and plastic.
I will try the mesh settings once I have updated the driver and upgraded to 6.1. the reason I was using the version I have is that I could not get the later versions of 6.0 to print correctly and there was an issue with images in panels (that I use for a logo block). It appeared on the screen in print preview but would not print ?
