I’m using Rhino 6 to slice a body. I do this for a laser process.
The slicing itself works like a charm and I can use Rhino without any problems. But when I select the body, Rhino becomes unusably slow.
Is this something that can be solved by upgrading the hardware or can I tweek the settings?
Is this a known problem?
A person with your same name is listed as missing from Carson Washington, USA. If this is you, I am glad you are well. Call Sheriff Helton, regarding case number 19-05187. Let him know you just want to be on your own, and then we can quit looking. If this is not you, I apologize for this message and be well.
