Rhino 6 update error message
unhandled
(Akeswins) #1
Hello, i’m using Rhino 6 and it has been running correctly.
Yesterday I installed last update and problems started.
When i run the program,these message appear
cat
in addiction, Rhino always crashes if I try to run systeminfo.
It seems this update must be fixed as soon as possible… anyway, someone else have the same problem?
Thanks
(Akeswins) #2
here the details of the debug
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell’eccezione **************
System.Runtime.InteropServices.ExternalException (0x80004005): Errore generico in GDI+.
in System.Drawing.Graphics.MeasureString(String text, Font font, SizeF layoutArea, StringFormat stringFormat)
in System.Windows.Forms.Label.GetPreferredSizeCore(Size proposedConstraints)
in System.Windows.Forms.Control.GetPreferredSize(Size proposedSize)
in System.Windows.Forms.Label.GetPreferredSize(Size proposedSize)
in System.Windows.Forms.Layout.TableLayout.InflateColumns(ContainerInfo containerInfo, Size proposedConstraints, Boolean measureOnly)
in System.Windows.Forms.Layout.TableLayout.ApplyStyles(ContainerInfo containerInfo, Size proposedConstraints, Boolean measureOnly)
in System.Windows.Forms.Layout.TableLayout.LayoutCore(IArrangedElement container, LayoutEventArgs args)
in System.Windows.Forms.Layout.LayoutEngine.Layout(Object container, LayoutEventArgs layoutEventArgs)
in System.Windows.Forms.Control.OnLayout(LayoutEventArgs levent)
in System.Windows.Forms.TableLayoutPanel.OnLayout(LayoutEventArgs levent)
in System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
in System.Windows.Forms.Control.PerformLayout()
in System.Windows.Forms.Control.ResumeLayout(Boolean performLayout)
in System.Windows.Forms.Layout.LayoutTransaction.Dispose()
in System.Windows.Forms.Label.OnTextChanged(EventArgs e)
in System.Windows.Forms.Control.set_Text(String value)
in RhinoWindows.WindowsLocalization.LocalizationStringTable.LocalizeControlTree(String formName, String formClassName, Control ctrl, ToolTip[] tooltips)
in RhinoWindows.WindowsLocalization.LocalizationUtils.LocalizeForm(Assembly assembly, Int32 languageId, Control form)
in RhinoSplash.LicensePanel.Init()
in RhinoSplash.Splash.InitializeLicensePane()
in RhinoSplash.Splash.RefreshLicenseDetailsPane()
in RhinoSplash.Splash.MainBodyPanel_Paint(Object sender, PaintEventArgs e)
in System.Windows.Forms.Control.OnPaint(PaintEventArgs e)
in System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
in System.Windows.Forms.Control.OnPrint(PaintEventArgs e)
in System.Windows.Forms.Control.WmPrintClient(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 4.0.0.0
Versione Win32: 4.7.2650.0 built by: NET471REL1LAST_B
Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RhinoWindows
Versione assembly: 6.4.18124.12321
Versione Win32: 6.4.18124.12321
Base di codice: file:///C:/Program%20Files/Rhino%206/System/RhinoWindows.DLL
RhinoCommon
Base di codice: file:///C:/Program%20Files/Rhino%206/System/RhinoCommon.DLL
Rhino.UI
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Rhino.UI.DLL
Eto.Wpf
Versione assembly: 2.4.6698.22852
Versione Win32: 2.4.6698.22852
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Eto.Wpf.DLL
Eto
Versione assembly: 2.4.6698.22835
Versione Win32: 2.4.6698.22835
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Eto.DLL
System.Runtime
Versione Win32: 4.7.2558.0
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
System.Drawing
Versione Win32: 4.7.2634.0 built by: NET471REL1LAST_C
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
PresentationCore
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Configuration
Versione Win32: 4.7.2558.0 built by: NET471REL1
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Collections
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Collections/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Collections.dll
System.Reflection
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Reflection/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Reflection.dll
Microsoft.WindowsAPICodePack.Shell
Versione assembly: 1.1.0.0
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Eto.Wpf.dll
System.Reflection.Extensions
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Reflection.Extensions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Reflection.Extensions.dll
System.Threading.Tasks
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Threading.Tasks/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.Tasks.dll
System.Globalization
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Globalization/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Globalization.dll
Xceed.Wpf.Toolkit
Versione assembly: 3.2.0.0
System.Linq.Expressions
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Linq.Expressions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Linq.Expressions.dll
System.ComponentModel
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ComponentModel.dll
System.Threading
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Threading/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.dll
System.Linq
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Linq/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Linq.dll
WindowsFormsIntegration
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
RhinoSplash
Base di codice: file:///C:/Program%20Files/Rhino%206/System/RhinoSplash.DLL
Accessibility
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Net.Http
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
System.ServiceModel
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Proxy
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Proxy.DLL
ZooClient
Base di codice: file:///C:/Program%20Files/Rhino%206/System/ZooClient.DLL
ValidationClient
Base di codice: file:///C:/Program%20Files/Rhino%206/System/ValidationClient.DLL
Newtonsoft.Json
Versione assembly: 10.0.0.0
Versione Win32: 10.0.3.21018
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Newtonsoft.Json.DLL
CloudZooClient
Base di codice: file:///C:/Program%20Files/Rhino%206/System/CloudZooClient.DLL
System.Runtime.Serialization
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Core.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Core.resources.dll
SMDiagnostics
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
System.RunTime.Serialization.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Runtime.Serialization.resources.dll
jose-jwt
Versione assembly: 2.4.0.0
Versione Win32: 2.4.0.0
Base di codice: file:///C:/Program%20Files/Rhino%206/System/jose-jwt.DLL
crypto
Base di codice: file:///C:/Program%20Files/Rhino%206/System/crypto.DLL
Newtonsoft.Json.Bson
Versione assembly: 1.0.0.0
Versione Win32: 1.0.1.20722
Base di codice: file:///C:/Program%20Files/Rhino%206/System/Newtonsoft.Json.Bson.DLL
System.Numerics
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Data
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Runtime.Extensions
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Extensions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Extensions.dll
PresentationFramework.Aero
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
PresentationFramework.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_it_31bf3856ad364e35/PresentationFramework.resources.dll
PresentationFramework-SystemXml
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
System.Management
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
websocket-sharp
Versione assembly: 1.0.2.59611
Versione Win32: 1.0.2.59611
Base di codice: file:///C:/Program%20Files/Rhino%206/System/websocket-sharp.DLL
PresentationCore.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationCore.resources/v4.0_4.0.0.0_it_31bf3856ad364e35/PresentationCore.resources.dll
System.Web
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
UIAutomationTypes
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
System.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.resources.dll
System.Drawing.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_it_b03f5f7f11d50a3a/System.Drawing.resources.dll
System.Windows.Forms.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
************** Debug JIT **************
Per abilitare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell’applicazione o del computer (machine.config).
L’applicazione inoltre deve essere compilata con il debug
abilitato.
Ad esempio:
Quando il debug JIT è abilitato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
#3
Yes, this is a known bug with SR4 running in Italian. They are working on a hotfix for this.
–Mitch
Rhinoceros 6 Error: "Command did not register"
(Akeswins) #4
OK, thank you .
(Brian Gillespie) #5
RH-45961 and RH-45962 are fixed in the latest Service Release (6.4.18130.19341)
(Akeswins) #6
I just installed the 6.5.18132.05131 , the problem is solved.
Anyway, still remains another bug: if i click in view properties , nothing happens.
#7
It’s not a bug per se… That function is already covered in the Properties panel when nothing is selected… So if that is open and docked, the viewport menu item appears to do nothing… If the Properties panel is not visible, choosing “Viewport properties” will show the panel…
(Akeswins) #8
understood! thanks
