SMC2
1
Hello every one
recently i have à polysurface in a block that don’t appears.
rhino 6 SR8 show this object in wirframe mode but
in render mod the object didn’t appear.
The link shared on my file
Display bug object.3dm
https://smc2.box.com/s/ydpt7vpyeszptvx08sepsrnp74j6yzu1
Best regards
JavierG
(Javier)
2
not always is a bug. try to explode and rejoin the object
SMC2
3
Thanks for your response But
I use the block edit command and.
If i explod the polySrf and rejoin all sufaces then the display is OK
but if i close the blockedit editor then the diplay of my object is off
pascal
(Pascal Golay)
4
Hello - see if running ClearAllMeshes and then reset the view to shaded helps here.
SMC2
5
Hi Thanks you Very much.
the “ClearAllMeshes” command is very good
the display is good
very thank
