Rhino 6 SR12 Release Candidate Available
Rhino 6 SR12 Release Candidate 3 (6.12.19008) is now available
Bugs Fixed:
  • Cycles: Matte materials raytrace all black using cubin files compiled with CUDA 10 (RH-49636)
  • Delete: Deleting lots of history objects and parents is slow (RH-49741)
  • Display: GH text tag does not show in layout (RH-50142)
  • EdgeSrf: Leaks memory (RH-49971)
  • File IO: Error message on cancel (RH-49871)
  • Localization: Typo in en-usEtoRdkUI.xml (RH-49954)
  • Make2D:
  • Mesh: UnweldVertex: Should work with SubD vertices? (RH-49762)
  • No Subsystem: Floating previews are white while resizing (RH-49955)
  • Print: Picture not Printing with Detail Clipping to Rhino PDF (RH-49079)
  • Purge: Hatch in block changes pattern on purge, save and reopen (RH-49808)
  • RDK:
    • CRhRdkTexturedContentField is essentially useless (RH-43752)
    • DragDrop datasource for Content Library Dialog (RH-49734)
  • Rendering:
    • Adjusting saturation for an HDR in a Renv affects lighting intensity too much (RH-38732)
    • Custom render meshes are not rendered by third party renderers (RH-50072)
  • SDK: RhinoCommon: Wish - Add linked or linked/embedded instance definition to File3dm (RH-49968)
  • SelectionFilter: Sub-objects checkbox visibility (or general case) sizing bug (RH-49817)
  • ShowEdges: Zoom action improvement (RH-49928)
  • SubD Editing: Missing SubD faces when extruding an Ngon with creased edges (RH-49815)
  • SubDFromMesh:
    • Change the name of SubDfromMesh to ToSubD (RH-49840)
    • ToSubD - remove shaded in all views option. (RH-49991)
  • Subobject Selection: Select one menu has wrong texts (RH-49986)
Crashes Fixed:
  • Cycles: :CUDADevice::reserve_local_memory – Access Denied (RH-48541)
  • No Subsystem: Commands.ViewModels.MeshRepairWizardViewModel.UpdateCheckStatesAndLog () (RH-49882)
  • Rendering: rdk!ShrinkDataInt – Access Denied (RH-49175)
Enhancements:
  • Explode: Exploding linked block makes all layers visible (RH-49038)
  • Snapshot:
    • MatchSnapshot command added to copy snapshot object properties (RH-50000)
    • Simple drag and drop added to snapshot panel (RH-50001)
Features Added:
  • SDK: RhinoCommon: Have a way to tell an ObjectPropertiesPage (or other panel hosts) when they are closed/disposed (RH-49990)
