Application name with errors: Rhino.exe, version: 6.1.18037.13441, timestamp: 0x5a7a2f9b
Module name with errors: VCRUNTIME140.dll, version: 14.11.25506.0, timestamp: 0x5967d7ce
Exception code: 0xc000041d
Error offset: 0x000000000000c500
Process identifier with errors: 0xb88
Start time of the application with errors: 0x01d3a3f4d34671ee
Path of the application with errors: C: \ Program Files \ Rhino 6 \ System \ Rhino.exe
Module path with errors: C: \ Windows \ SYSTEM32 \ VCRUNTIME140.dll
Reporting Identifier: 34bf29b7-c02c-40e5-83e4-3c3bc92f64b4
Full name of the package with errors:
Relative application identifier of the package with errors:
Was there a crash reporter that popped up when this happened and if so did you send it in from the email you use here on the forum?
If there’s a file that you can reproduce this with, either 3dm/GH or both, please post it or send it in to tech@mcneel.com as well listing the specific steps you take. I’m curious if maybe something is being calculated in a Rhino viewport or in the GH canvas when this happens such as using Raytraced mode or Kangaroo in GH.
Can you also run the SystemInfo command and provide the text it reports? Thanks.
This time it crashed just by placing one of Grasshopper’s built-in components in the document. The solution had just three components and the model only contained a NURBS curve. I completed the Crash Report Form each time.
Thanks for sending in the report. We searched for the email address you use here in the forum but didn’t find any crash reports. Did you send them in from another email address? There’s a field in the crash reporter where you enter your email address.
I was having intermitent connection at the time maybe they were not sent at all.
I rolled back to SR0 and the problems are gone so far maybe this weekend I can give it try again.
Oops I have just discovered the memory dumps at %userprofile%\AppData\Local\CrashDumps
Do they contain any personal data? Can I directly post them here?
maybe better to post them with rhino3d.com/upload - copy the link to this discussion so we know to what the upload belongs to
Done!
Hi LowEndSilicon,
Is there any chance we could get the Grasshopper file you’re using when you get the crashes? The crash looks like it’s in display code but the code in question looks sounds ( the crash is actually an unhandled exception in the c runtime). We like to try repeating your crash here, in a debugger.
Tim
Hi @LowEndSilicon,
This has been reported before:
https://mcneel.myjetbrains.com/youtrack/issue/RH-44109
We’re looking to find a way to repeat it here…
Thanks,
– Dale
Sadly the crashes took place before I could save the Grasshopper files.
I’ve had what seems to be the same problem several times, I have sent the crash report with the .3dm file attached.
–edit–
When the last crash happened, I was trying to put back the camera center to the axis origin in perspective viewport.
I rencently upgraded to SR2 and the chrash still takes place (only when grasshopper is running). This time it crashed when I was tweaking the material parameters of custom preview geometry. Other times it crashes just by placing the first component when everything else is empty. Rolling back to SR0 is the only fix for me apparently.
Another hang, this time while running Grasshopper and with faulting module VCRUNTIME140.dll. The crash report was filled with the name LowEndSilicon. Definitely you have introduced a serious stability bug in both SR1 and SR2.
Any news on this topic? I would like to be able to use the latest SR as it provides some other fixes.
My colleague had a problem with Grasshopper 1.0 crashes and the problem was solved by strictly using only GH plugins updated for GH1.0 / Rhino 6. In his case it was outdated Elefront causing all the crashes.
Cheers
Jonas
There is an SR3 release candidate that should fix this crash.
I do not think this is the case as I tried SR0 and SR1/SR2 with the exact same Grasshopper plug-ins and the crash does not take place with SR0.
I used to try new releases hopping they would fix the crash, but I am tired of losing files. I will not update or test new releases unless the changelog refers to a fix of this specific crash. There is one fix for a Grasshopper crash but sometimes it is just dropping the first component to the canvas and it immediately freezes.
I worked on this crash. I was never able to repeat it on my computer, but the changes I made should mitigate this crash. I can’t guarantee that what is causing your system to crash is the exact same crash reported by others, but it was a pretty high frequency crash that affected a lot of people.
