Rhino 6 saves extremely large files (simple 2D drawing, no exploded block instances etc.)
I have quite simple 2D drawing, but Rhino 6 saves it as 700MB file (plugin data & textures disabled, save small enabled). Save geometry only produces 2,4MB Rhino file.
See link with sample files:
I ran the Audit3dmFile command on the big file and looked through the report.
Here are the big data things I found:
Embedded image Table:
2 embedded images, 2171514 bytes (offset 3627079 to 5798593)
There’s your big data.
I never had this file so big until SR18. Here you have the previous version with same embeded images, which takes 14,3MB only.
http://bit.ly/2LpSPQE
Export selected as v6 produces the same big file (700MB, save small checked, textures, plugins data, notes unchecked), export selected as version 4.0 gives neat 3MB 3dm file.
@John_Brock UPDATE: Issue is related to this geometry - results from Make2D on mesh 3D object. Each 2D pillow takes up to 340MB space on export.
Export selected to Rhino 6,5 - 640MB
Export selected to Rhino 2 - 135kB
both exports are here:
http://bit.ly/2Lmy5sY
The first large file you posted named LIC-STUD-20190905.studie final CELEK.3dm (699,052,026 bytes). Running Audit3dmFile produces these items of interest:
Properties Section: 3604859 bytes (offset 431 to 3605290)
Settings Section: 21789 bytes (offset 3605290 to 3627079)
286 texture mappings with 112 plug-in data items, 688299386 bytes (offset 5798593 to 694097979)
0 materials, 24 bytes (offset 694097979 to 694098003)
3 linetypes, 689 bytes (offset 694098003 to 694098692)
23 layers with 1 plug-in data items, 6396 bytes (offset 694098692 to 694105088)
144 groups, 18838 bytes (offset 694105088 to 694123926)
1 annotation styles, 1424 bytes (offset 694123926 to 694125350)
0 lights, 24 bytes (offset 694125350 to 694125374)
9 hatchpatterns, 3144 bytes (offset 694125374 to 694128518)
5 block definitions, 45333 bytes (offset 694128518 to 694173851)
5980 objects with 5934 plug-in data items, 4647237 bytes (offset 694173851 to 698821088)
0 history records, 24 bytes (offset 698821088 to 698821112)
7 user tables, 230914 bytes (offset 698821112 to 699052026)
Largest item is 286 texture mappings with 112 plug-in data items, 688299386 bytes.
Same thing in the last file you posted (make2D result - pillows export selected tov6.3dm). The largest item is 174 texture mappings, 639756786 bytes.
I’m not sure if there is a way see this data in Rhino or delete it. I don’t know why you would need texture mappings since the only geometry in these files is curves. Perhaps there is a bug in Make2D.
-Kevin
I never used texture mapping on the curves/2D objects. Mapping is not displayed in the inspector panel and cannot be removed.
It seems like bug in Make2D command. @John_Brock
