Rhino 6 Right-click on 'Import Annotation Style'
When importing annotation styles from 3DMs in Rhino 6, I can no longer right-click them to deselect all others like in Rhino 5. The same behaviour as with osnaps or the selection filter.
It is at all possible to bring back this functionality?
Hi Duncan - this does work here in the latest in-house build. Does it fail consistently for you? Are you in 6.16? (SystemInfo command)
Hi Pascal,
it seems so.
Rhino 6 SR16 2019-7-9 (Rhino 6, 6.16.19190.07001
I’ll respond again should the problem persist.
I’m experiencing the same issue here as well. Plus, after I import the annotation styles, the “OK” button won’t work. Have to click on the Cancel button to exit out of the dialog box. Not sure if anyone else is have this problem
This is now fixed for me since Rhino 6 SR19 2019-10-22 (Rhino 6, 6.19.19295.01001, Git hash:master @ 0af62045bd35259d4c2367dbf7f9ef94ded29299) !
Many thanks.
