Rhino 6 - problem with MeshFromLines
It seems that MeshFromLines command does not work. I used 3 and 4 straight, intersecting lines as the input, but all I got was error message: “Lines did not form any polygon.”
Hello - Yeah… granted this is not very clear, but the line end points must coincide… The prompt & Help needs to be tuned up.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43779
https://mcneel.myjetbrains.com/youtrack/issue/RH-43780
thanks,
