Rhino 6 Plug-ins - Construction Plane error
Rhino 6 Plug-ins
I use function “doc.Objects.AddText (sText, Plane, Height, Font, False, False)”
when I import and assign Plane a value
“Dim Plane As Rhino.Geometry.Plane = doc.Views.ActiveView.ActiveViewport.ConstructionPlane ()”
I get the result {Origin = 0.0.0 XAxis = 1.0.0, YAxis = 0.1.0, ZAxis = 0.0,1}
everything works well
but if I open, I get this result ‘doc.Views.ActiveView.ActiveViewport.ConstructionPlane ()’ threw an exception of type ‘System.NullReferenceException’
and the program stops
//Michael
Hi @UtsMicke,
Can you post some code code that runs, so we can run it here, that does not work for you?
– Dale
Hello sends with my vb.net project
VBProjectXx.zip (251.6 KB)
It works if you import but not if you choose to open
/Michael
Hi @UtsMicke,
When you are opening a new file, the Rhino document you are populating is empty. Thus, you cannot do this:
Dim plane As Plane = doc.Views.ActiveView.ActiveViewport.ConstructionPlane()
because no views yet exist. You’ll need to get a plane in some other manner.
Does this help?
– Dale
Little is there any example code ?
/Michael
HI @dale,
Instead of this:
maybe you can do this:
Dim plane As Plane = Plane.WorldXY
– Dale
Thanks for the code
/Michael
