Spotted a render bug for OneView viewport renders.
Whilst using OneView, the CPlane indicator in the top right hand corner is replicated on the renders if you enable annotations.
If the render resolution Is turned up the indicator is replicated 4 times across the screen.
Simple fix meanwhile is to turn off OneView.
If anyone can delicate error for confiramtion, that would be great.
i have a suspicion it may be my 4K Monitor, I’ve had a similar issue with a plug-in render.
That used to be an issue (i.e. labels appearing on prints and renderings) but appears to be fixed in more recent versions.
To be sure, are you using the Render command in this process? If not, can you clearly state which steps you take? Also, which version of Rhino are you running?
Finally, the YT item related to this is: RH-39848 @stevebaer, if you ask me, this one is fixed in:
