Hi…,
this is a customer note/(wish back to Rhino 5 ), that _OffsetSrf creates polysurfaces in this case. Rhino 5 did it with one face.
Thanks
Michael
www.flexiCAD.com
Hi…,
Thanks
Michael
www.flexiCAD.com
Hi Michael - I see that, thanks.
In V6, if you chose the option Loose = Yes, You can avoid this situation.
Plus, you can maintain the points structure.
Hello - you can yes, but cylinders have exact cylindrical offsets so there should be no need - the output should be another cylinder.
Yes, true, the cylinder will have a cylindrical offset,
But we can avoid the issue of having the offset of an open surface
Resulting in an open polysurface.
That was the reason behind the thread
