Just upgraded to rhino 6 for mac. I work on a vpn to a server so all files are saved there. When I try to reopen a file it will only open as a read only file. If I copy it to my desktop it opens as normal.
The wip also did this.
If I save it as a rhino 5 I do not have this problem.
It is something in rhino 6 that is doing this.
Anybody have any ideas on how to fix this?
Thanks
Hi Gurney,
Check this thread
Read-only file
Petr
This is interesting because it seems to suggest it potentially isn’t specifically relating to a NAS or the read cache on a NAS, but just files saved remotely.
@gurney1 do you know what the VPN server is running on? Is it a NAS drive?
Its not a NAS drive.
Just a standard windows machine I think.
It may be being backed up dropbox though, could this be the problem?
I will try and fine out more.
I though it was just the wip but disappointingly it does it with the official release.
The VPN machine is operating on windows 8 and has 5 drives in it working on a raid system.
It is also backed up to dropbox.
Thanks Petr
I had seen this tread.
No solution though
Anyway, as far as I can remember, there was a period when the WIP version acted normally…
