Rhino 6: Lock objects, control points still visible (why?)
Hi developers,
when I lock a curve:
  1. I select a curve, (control points become visible, since Rhino 6)
  2. I start the lock command
  3. curve is locked, control points ars still visible, but not selectable. I would expect, that the control points are off.
Thanks
Michael
www.flexiCAD.com
hehe…
and old quote of mine:
Ceterum censeo Carthaginem esse delendam : Locking a curve with points on should turn those off…
Showing points of locked curves is intended behavior…
Why, no good reason comes to my mind?
Well, for example you create a surface with said curve and you want to align the surface control points with the curve control points without mixing them up.
I agree with Michael. I don’t personally have any use for showing points of preselected, locked objects - I just find the behaviour slightly annoying…
Please reconsider.
Philip
