Rhino 6 history warning
Hi all,
In Rhino 6 everytime I need to move a dimension I get the following error message “the move command broke history on 1 object”. I don’t have history on and when I have to dimension object I have to move them around frequently so this message is very annoying, any way to remove it for good? In rhino 5 it was working perfectly
Are you sure you turned off History via the History command. If you just click it off on the bottom it comes back on with new objects.
The history on dimensions can’t be turned off in V6, not completely anyway, at this time. It is a nuisance.
Hi Jim, All - the History command has a separate option for annotations.
Just upgraded to Rhino 6, this is a real pain.
