I’ve noticed that in grasshopper 1.0, the point on curve component still displays the point even when disabled.
is this some kind of feature i’m no aware of? seems like a bug
It doesn’t do that here:
Which version of Rhino are you running?
I’m running Version 6 SR5 (6.5.18155.13161, 06/04/2018)
maybe i should reinstall?
I’m using an in-house 6.7 version. @DavidRutten, have there been any recent changes related to this?
Don’t re-install, that won’t fix this. Updating to the newest available release might fix it, but it doesn’t seem important enough to abandon your current update schedule.
(looking into whether this was fixed since 6.5)…
Result; it hasn’t, it’s still happening on my own custom build, which uses the most recent code. Under certain conditions the problem may not be there which I suspect is what @wim is seeing, but I can definitely repeat here.
Logged under RH-46778.
