Rhino 6 for Windows SR17 Release Candidate 4 (6.17.19212) is now available.
Bugs Fixed:
- BoxEdit: Incorrect size info (RH-53923)
- Build Process: Rhino3dm (iOS): Consider adding a reference to System.Drawing.Common (RH-54050)
- Display: Draw ground plane intersections with shader (RH-53855)
Crashes Fixed:
- Eto: System.ObjectDisposedException: Eto.Widget.get_Handler () (RH-52467)
- No Subsystem: Method not found: ‘Void Rhino.Render.CustomRenderContentAttribute…ctor(System.String, Boolean, System.String, Boolean, Boolean, Boolean)’. (RH-53844)
Performance Improvements:
- Display:
Regressions Fixed:
- No Subsystem: Correct typefaces not always found for certain languages (RH-53897)
