Why fail when I export a Rhino 6 file to .obj?
All export settings are default.
Hello - as far as I can see, in V6, if only a curve is selected it fails - this looks like a bug to me - include one polygon and it works - use 3dFace
to make a polygon, for now.
Thank you for your reply so fast.
But actually not only one curve in my project, this is the whole selected which to be exported. it didn’t work to .obj
PSG.gh (64.4 KB)
Hello- please post a small sample of the geometry that you are exporting.
source or screenshot?
Hi -
A 3dm file.
Note that the issue with exporting curves only was fixed in Rhino 7.6.
Is no solution in Rhino 6?
Hi -
There are only curves in that file and the issue with exporting only curves won’t be fixed in Rhino 6. You can add a simple plane and then export all.
