Hi Jaison - object names are exported as far as I can see - that is, re-importing a step file to Rhino correctly shows object names. So the question may be with the importer for Abaqus. I see that SolidWorks also does nothing that I can see with object names.
Thanks for the reply yes I agree there is something strange with the Abaqus.
With Ansys I tried there was no issue there.
But with Abaqus it seems it is some thing to do with the part name rather than the object name.
My second proposed idea will work. But the work flow would be much easier if there is a proper Rhino running script
That can write several step file with layer name as a file name with the specific layer name object s in that file.
I completely understand but at least this is workaround to solve this issue.
As my part name & layer name are the same.
I don’t know how this script for export objects with layer name as step file name works so to have several step file depending on how many define layers in Rhino.
I would deeply appreciate if you could look in to the previous threads and the point 1 to 3.
I have a feeling it is rather a simple script/revision to the existing attached script for someone with the Rhino script knowledge.
