Rhino 6 erroneous annotation renaming
Yesterday I created an annotation style named: “ISOCPEUR [ 5 : 1 ]”.
As I open my file today the style has been renamed to " 1 ]".
Can you reproduce this in Rhino 6? Rhino 5 seems fine with the naming.
I thought if perhaps it’s due to the colon, but I have other (older) styles in the file when it used to be Rh5 with a colon that seem fine. It’s only these newly created ones that have the problem. Could it be due to the brackets …?
Thanks,
Duncan
Hi Duncan - I see this- thanks, I do not know the reason but brackets seems like a likely culprit. I’ll put it on the pile.
Hm. If I add an underscore inside the brackets it all works so far:
ISOCPEUR [ 5 :_1 ]
dash works…
ISOCPEUR [ 5-1 ]
@DuncanW - it seems to be the spaces… this works here:
ISOCPEUR [ 5:1 ]
Specifically, the space-colon-space combo, is how it looks…
https://mcneel.myjetbrains.com/youtrack/issue/RH-54542
Thank you Pascal.
Hoping for a soon fix.
