Rhino 6 bugs
Hi
I have found some small bugs.
  1. I had problems importing/opening a obj file, There is no problem opening the obj file in Rhino 5. It is only one file so far. I have no problem opening other obj files.
  2. When opening a new file, and then sort layers by name, all layers disapear, until I click the “show all layers” filter button. This happens every time I open Rhino.
Hi @chrbjerre,
  1. Could you please paste the information found in Help -> System information...?
  2. Would it be possible to send us the obj file which is not importing correctly? You can attach it here or send it to https://www.rhino3d.com/upload. Put david.eranen@mcneel.com in the recipient field.
  3. Does the “layer disappearing” problem happen for all files, or just a specific file?
-David
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
GeForce GT 730/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.35)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-23-2018
Driver Version: 23.21.13.9135
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 6\Plug-ins\import_OBJ.rhp “Import_OBJ”
  1. I have send you the file
  2. The layer disappears in all files.
@chrbjerre,
I was able to import the OBJ file into Rhino 6. It was slower to import than V5, though. I have created a YouTrack item about the slowness (public view not permitted due to your file being confidential).
Were you also able to import it? If not, what happened? Did Rhino 6 crash?
Thanks,
-David
@chrbjerre I can reproduce the layers disappearing after sorting by name. I will make a YouTrack item for it.
Thank you!
-David
I just got the message “error importing file”
@chrbjerre Interesting. Could you post a screen shot of your OBJ import dialog so that I can use the same options as you do?
Thanks,
-David
screenshot
@chrbjerre,
I tried importing using your options, and using the exact same Rhino version as you do. The import worked for me. So now the question is, what’s the difference between our setups?
I also have trouble importing OBJ in Rhino 6! Using latest build.
Hi @Morten_Fanous_Tejlga,
Do you also get “Error importing file”?
-David
Hi Morten - are you also running 6.3? (Help> About Rhinoceros). You might try (and I know this is not a fix, more of a test) renaming the mtl file, if there is one - there was a bug, fixed in 6.4 where mtl files that sometimes accomany objs were causing trouble in some cases.
Hi. It just imports nothing…
Hi Pascal.
Thanks - using 6.3.18090.471 - Check for for update said I have latest build, but my trial just expired, so that might be the reason.
RH-45933 is fixed in the latest Service Release Candidate
I have been having problems using blocks. Specifically copying and pasting between blocks. Whenever I attempt to paste something into a block, it explodes, and the BlockEdit dialogue box is frozen.
Hi Jens - can you please run the Rhino command SystemInfo and copy/paste the results here?
_Pascal
Hello again. Sorry for the late reply.
Rhino 6 SR4 2018-5-4 (Rhino 6, 6.4.18124.12321, Git hash:master @ 396f4c3420cadef29ac36e4307c8f98f7753c933)
Licence type: Commercial, build 2018-05-04
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: AARLT6012
GeForce GTX 1070/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.16)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-30-2017
Driver Version: 23.21.13.8816
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython”
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin”
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper”
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
Hi Jens - thanks - I see you’re running 6.4 - please get the latest (Help > Check for updates, or here:
https://www.rhino3d.com/download/rhino-for-windows/6/latest ) That should work better,
Thanks - I’ll forward that to our IT department, as I can’t update for myself.
