Rhino 6 bug - Thickness command
The Thickness command displays offset surface (as a wireframe) only when the original surface is selected.
thickness%20bug%201
The Thickness command expects that the surface already has been selected. If it has not been selected, it works too, but it displays error message shown below.
thickness%20bug%202
Hello - Thickness is not a command but an option on PropertiesPage. I need to add a Pause in there on the button macro so you don’t get that error. Thanks for pointing that out.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44020
This is paper-cut - you have not mentioned the main bug.
I take it that is referring to this:
I’m sorry but I really don’t understand what that means.
(but then, I don’t understand when one would only want the offset - but that is perhaps not even the point…).
Yes. This is strange option. It seems that nobody needs it, so eliminate this option to eliminate the confusion.
The same bugs are in Rhino 6.3.
