Rhino 6.15 parallel view capture frame do not matches viewport!
This happens when you set scale more than one or change output picture size
and this is how picture looks with transparent background. So there is smthng with rgb pixels location
Hello - in the first two images it’s the edge thickness that is the problem, correct, or is the cropping from the view capture?? I’ll test…
Oh, i meant cropping
I use isometric presets - nw ne …
Are you using the Zoo Extents option within the Isometric command?
