I have a file containing a series of cuboids.
In Rhino 5 when BooleanUnion command is run, it works perfectly and mentioned shapes create a single closed solid.
However in Rhino 6, BooleanUnion command just fails. Why is that so?
For some reason the same rule applies in Grasshopper too: On Rhino 5 it works (0.9.0076). On Rhino 6 (1.0.0004) it fails.
Hello - it works in V5 but results in non-manifold edges- in V6 it works if you go one level at a time but it also makes non-manifolds - but the reason given for failing all at once in V6 is also non-manifolds. I’ll investigate some more…
Another thing that I find strange about the _BooleanUnion command (both on Rhino 5 and Rhino 6) is that it undoes its results if it fails to boolean union one of the parts from the initial selection.
Why is this so?
Let’s say that I select a series of cubes, one next to each other. So they share the same vertical face. And I have the upper attached solids. If I select all of this geometry (both the upper attached solids and these touching cubes) and run the _BooleanUnion command in Rhino 6, I will get the “Boolean Union failed” message, and boolean union of the touching cubes will be undone, even though it should succeed.
Thank you @pascal,
Another interesting thing is that in Rhino 5, after running _BooleanUnion command, I can explode and join the srfs and I get a perfectly closed polysurface.
