Rhino 5 splash screen is annoying
So I found a hack that works on Windows 7 if you want to open by double clicking through explorer. This works on my machine:
This requires a batch file named OpenRhinoNoSplash.bat
The batch file needs to be saved in a folder that is listed in the PATH variable ( I used “C:\Windows”)
C:\Windows\OpenRhinoNoSplash.bat
Contents of the batch file:
rem ==============
rem start rhino without a splash screen
start “” “C:\Program Files\Rhinoceros 5.0 (64-bit)\System\Rhino.exe” /nosplash %1
Exit
rem =============
In regedit goto:
HKEY_CLASSES_ROOT\Rhino5x64.Document\shell\open\command
Do yourself a favor and export this key as a backup just in case you need to revert.
Now replace:
“C:\Program Files\Rhinoceros 5.0 (64-bit)\System\Rhino.exe” “%1”
(This may be different depending on your install location)
with:
“OpenRhinoNoSplash” “%1”
Now when you double click on a Rhino Doc through explorer, it will open without the splash (you do see the quick flash of the console window)
HTH,
tom
Oh thanks for the right key. /nosplask can be added directly to the key, no bat needed:
“C:\Program Files\Rhinoceros 5 (64-bit)\System\Rhino.exe” “/nosplash” “%1”
Even better - nice catch!
(I see now - my mistake was not separating out that string in the reg…)
Yes! That works. Thanks a bunch!!
I appreciate the effort to make the splash screen usable. I generally like its function. BUT… until a method is found that doesn’t make rhino keep popping to the top as a file is opening while I’m trying to do other things, this splash screen is more hassle than it is worth – I keep messing things up. I’d like to ask again for a switch to turn it off in Rhino 5 without doing some crazy registry hacks, or adding /nosplash that only works when opening rhino without opening directly from a file. The splash screen is driving me nuts.
its so simple to pass away the splash screen,I just delete that particular file from the directory of Rhino5 RhinoSplash.dll and its done…
“C:\Program Files\Rhinoceros 5\System\RhinoSplash.dll”
Hahahaha, what a brilliant hack.:rofl: But it works and will save me a lot of time! Awesome!
These forum “archives” really can be extremely useful !
Unacceptably slow Rhino6 startup times (30+ seconds some times) banished at the stroke of a “/nosplash” command line option.
Many thanks steveB!
6 years later here I am still using this method to get rid of that annoying screen. thanks for this comment.
