Just done another.
draw line project on to ensure at Cplane.
create helix pitch 5.0
diameter 4.35
reverse twist no
all whilst project Osnap was on.
result move so end is at my wires start point,
pipe round end
dia 1mm
hit enter and enter and get a mess
just repeated this without project on, and still a mess.
In another of your recent threads, Wim pointed out that the absolute tolerance in the problematic version of your file was set to 0.1 (instead of the typical 0.001). So I set the tolerance to 0.1 in this file and that caused the twisted pipe you see. Set the tolerance to the default 0.001 and you’ll get the clean pipe Kyle shows.
And maybe check the tolerance setting in the source file for each of the various issues you are currently experiencing!
Where is that tolerance setting ?
in the past no doubt I have been told its too tight and to loosen it !
Rhino wip9 comes ‘as is’ and I havent altered any tolerances as far as I know., or have I ?
so have I done so to match previous versions, and the updates to WIP9 reinstate my settings,
…what does WIP9 come with ?
On the Options>Units page. It is set per document, so open the one where you see the problems appear and check that. Then check your template(s) to see what you are applying to new documents (but they are probably ok because you’ve been pasting into new documents and they have the default tolerance).
You may have changed the tolerance to see if booleans, say, worked better and left it that way.
