I’ve been running Rhino 5 on a 4K computer for over a year with no issues (aside from the tiny icons). Resolution is beautiful and line work looks perfect.
However, when I opened Rhino a week ago, the whole interace has become fuzzy. It’s still usable, but looks like I’m using it on a much lower resolution screen. At first I tried messing with OpenGL settings, anti-aliasing, etc., but the problem seems to be with the entire application, not the viewports. My system display scaling is set to the same as usual - 175%. Reset NVIDIA settings to default with no luck. This only appears to be happening with Rhino. Any thoughts?
Updated a while ago and thought I dealt with all those issues. I found the answer on the link you provided however - John’s suggestion to change compatibility settings worked for me. Thought I’d already tried that, but grateful for a fix. Thanks!!
I’m on Windows 10 Pro 1709, and cannot use this method to fix the blurry problem. There is no “compatibility” tab under properties. Can anybody provide a solution?
Good point. I right clicked on the folder instead of the app. So then I tried the method on the app icon, but my settings already have “Override high DPI scaling behavior” unchecked.
But I found a solution. I actually had to check the “Override high DPI scaling behavior” to make the screen clear.
