I used Matrix 9 software to open the file… everything seemed fine, but then a large gray area appeared in the 3D view.Thank you for reading and helping me.
Thiabui, you might need to upload the file in question . A little more explanation as well. Your title says one thing and your text says another. —Mark
It appears your perspective window may be in another view mode, perhaps rendered?
the grey appears to be your background color that is set in the rendered mode display preferences.
unless I’m confused.
Where can I check and edit it? … Do I need to adjust it in Rhino 8 or Rhino 5?
I created the file in Rhino 8 and then saved it as Rhino 5 using the SAVE file function with Rhino 5.
