Rhino 5.0 Error reading default.rui
I just had a blue screen from windows and it rebooted my system. After opening Rhino 5 back up it can’t read the rui file saying invalid character. Line 125114 position 32?
I tried loading in safe mode, get the same error.
Should I delete the RUI and run rhino again?
Try to use ToolbarReset command .
Thanks @foreigner
That did fix my Rhino Toolbars. My Paneling Tools toolbar still has an error loading. Not using it at the moment so not so concerned.
Try to load Paneling Tools plug in > Tools ., Options … Plugin … Install > Browse . …
Thanks for the input @foreigner but that didn’t work.
So I installed paneling tools from scratch but I still get “Root element is missing.”. It does have a drop down menu and the commands do function, just no toolbar.
It fixed the problem. Thanks!!
