Rhine complains of Missing Images that are not Used
I added some images to a file. I then deleted the images from the file. Then I deleted the images from the computer. Now I am gettiing messages of this type nonstop. How do I put an end to this/
The following files could not be read:
/Users/X/Desktop/1102AA uf Inner Bottom Plating FR12 -68.jpg
Please make sure the files exist and are not in use by another application, and try saving again
Hi John -
When Rhino 8 opens a file and encounters a missing image, you should be getting the following dialog box:
Here, you can select the images in the list and use the Remove button to remove those.
You should also be able to use the Purge command with the “Bitmaps”, “Materials”, and “Textures” options.
I had not reopened the file and was getting this incessant message.
Hi John -
I’m afraid I don’t understand.
You didn’t open a file but were getting error messages nonetheless? Could you post a screenshot of the message?
I open the file.
I add images.
I delete all the images I added.
The I delete the images from the system (realizing they are bad).
I do no close rhino.
From then I get incessantly errors that the files that I no longer am using are not on the system.
