We have one machine where our installer’s call to rhiexec to install our plugin fails. The following is the very short contents of the rhiexec log file.
Could you give us a hint what might be going wrong?
09/14/2016 15:27:11 25860 Info Start: rhiexec
version 6.0.16250.12021
64-bit
unknown Enterprise 6.2.9200.0
09/14/2016 15:27:11 25860 Info arguments:
"C:\Program Files\NVIDIA Corporation\Iray For Rhino 6\IrayForRhino6.rhi"
"/admin"
"/silent"
"/loglevel=Debug"
"/logfile=C:\log\rhiexec_log.txt"
09/14/2016 15:27:11 25860 Info Logging started: 2016/09/14 15:27:11
09/14/2016 15:27:11 25860 Debug Unknown InstallerDialog_Load starting (0%)
09/14/2016 15:27:11 25860 Debug Unknown InstallerDialog_Load ending (0%)
09/14/2016 15:27:11 25860 Info Initializing INIT START: (0%)
09/14/2016 15:27:11 25860 Error Exception: System.ArgumentException
Message: 1 is not a supported code page.
Parameter name: codepage
Source: mscorlib
StackTrace: at System.Text.Encoding.GetEncoding(Int32 codepage)
at ICSharpCode.SharpZipLib.Zip.ZipFile.ReadEntries()
at ICSharpCode.SharpZipLib.Zip.ZipFile..ctor(String name)
at RhiExec.Package.OpenZipFile(String filename)
at RhiExec.Package.get_Files()
at RhiExec.Package.FindFiles(Regex expression)
at RhiExec.Package.FindSingleFile(String pattern)
at RhiExec.InstallerPlatformSpecific.ContainsRecognizedPayload(AsyncReporter progress)
at RhiExec.Installer.Create(String packagePath, AsyncReporter progress)
at RhiExec.Engine.Engine.Init(String packagePath, AsyncReporter progress)
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RhiExec.View.InstallerDialog.<InstallerDialogShown>d__3.MoveNext()
09/14/2016 15:27:11 25860 Debug Unknown InstallerDialogClosing starting (0%)
09/14/2016 15:27:11 25860 Debug FinalExit Exiting installation with return code Initializing
09/14/2016 15:27:11 25860 Info Logging ended: 2016/09/14 15:27:11
09/14/2016 15:27:11 25860 Info Uploading this log file
09/14/2016 15:27:11 25860 Warning C:\Program Files\McNeel\Rhino Installer Engine\x64\..\RmaErrorReporting.exe not found
