In this case the guid is lower cased and is in normal braces.
This leads to the situation where what I suppose should end up in 1 directory ends up in 2 directories:
This picture is from %Appdata%\McNeel\Rhinoceros\5.0\Plug-ins\ where now two directories with almost similar names are found (the same text is greyed out in both cases)
So, my question is: shouldn’t the plug-in and its settings be stored in the same folder in %appdata%?
As for nice touches, I suppose rather than deleting the {} location its contents should be merged with the () location when the new RHI installer is running. This way any previous versions a user may want to revert to are not lost.
Yeah, I was thinking about that, and then decided it was probably not worth the effort, since reverting versions is still in the pipe-dream phase of development.
