RH8 - Popup - size setting
Good to hear i will keep shut until then :slight_smile:
@stevebaer Any news sadly it is still not working with 8.11
Have you tried the 8.12 release candidate? We did find a case that needed to be fixed based on input from another user. If 8.12 is still not working for you, we’ll need to spend time digging into your specific problem.
Running 8.12 here, installed yesterday. No change with a Container for the Popup, I’m afraid:
Even if I “nail” the Popup and resize it, the MMB Popup still gives me this. I’ve even tried changing the proportions (buttons wide x high), saving, closing and restarting but it makes no difference.
This is what I’d like to see:
It’s the chevrons thing that appears on the incorrectly proportioned toolbar that’s the killer. The buttons that cascade from it don’t carry the (custom) functions that I’ve assigned to the missing buttons so getting to the command I want is very long-winded. I’ve got to the point where I nail the Popup to the screen and just drag it around, a lot of the time. It’s less grief. Is there anything in the registry that can be cleared in an effort to get Rhino to learn a new behaviour?
No unfortunatly still the same behavior
@Gijs can you help investigate this? I don’t think I have a good grasp on all of the steps involved to repeat this bug.
@stevebaer Sure, I will look into it asap
I logged RH-84030 custom Popup container does not work correctly
In case you got any questions for the bug reproduction. Let me know i spent hours to find a workaround.
@Gijs you only reported the sizing problem
there is also a
  • change position of button
  • delete a button
  • customise the button
Changes get lost after closing and opening the button but with no real pattern of when it will happen.
hi @mi.land thanks,
RH-84035 Changes don’t stick in custom popup
I suspect this is all related. In my testing, the changes do stick, but require a restart of Rhino. Changes to macros do work on my end.
Let me know if the above report covers what you are experiencing or if it is different from what I described, thanks.
This issue absolutely drives me crazy. I use RH8 on two computers every day due to a daily routine mandated by my kid’s schedule. The two instances use the same VUI file that I keep in a cloud folder. And the popup will show up in different size in each of them! Can you imagine how painful this is for a Rhino user of 25 years?
RH-73095 is fixed in Rhino WIP
Does this mean that the macro workaround promoted by @Gijs (?) no longer needs to be employed in V8?
That said, his fix has worked very nicely for my needs.
@MattE I’m not sure what workaround you are referring to here. In any case, the issue that is fixed is fixed in Rhino WIP not in Rhino 8
