Rh8 mac keeps crashing on macbookpro M1pro with 64gb
I keep getting a spinning beachball and have to force quit
Any idea what could be wrong?
Here is the crashreport
<?xml version="1.0" encoding="utf-8" standalone="yes"?> 0 2 2 1 0 8 2e3e2cbc-163f-4806-97b2-3d0cf9237c97 Shaded 2 100;54;54;54 100;0;150;0 637534158135499960 false 20240503_SolarLab.global_simulation-FORBEDRET OG HURTIGERE-2.gh 0 -413 -2940 1.0445974 0 0 false false false false false true true false false false true true false false false true false false true true true true false false true false true false false false false false false false false false true true false false true false true false true true true true false true true false false false false false true false true false false true false false true true false true false true true false false false false true false true true true true false false true false false true false true true false true false false false false true false false true false false false true true true true false false true false false true true false false false true true true 1 Robert McNeel & Associates 00000000-0000-0000-0000-000000000000 Grasshopper 8.6.24101.5002 1 7f5c6c55-f846-4a08-9c9a-cfdc285cc6fe Scribble false 534.79846 3590.8447 750.527 3592.4993 750.385 3611.0046 534.6565 3609.35 A quick note Microsoft Sans Serif c0130829-73bd-4f1e-9e76-2a39de8199d4 false Scribble Scribble 25 CO2 & Trees saved 529.6565 3585.8447 225.87048 30.159912 534.79846 3590.8447 true
Hi Anders, please run SystemInfo in the Rhino command line. Thanks
here you are
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05002, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: en-DK (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (2056 x 1329 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/and/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Corgi/0.6.0/Corgi.rhp “Corgi” 0.6.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.6.24101.5002
I see all your crashes involve Rhino 7 files. Can we see one of those? Either posted here or sent privately (with a link to this thread in the comments) here.
If possible please update to 8.7 (via Rhino8>Settings>General> Set updates to Service Release Candidate. Thanks
Thanks, it opened on my M1 with no issues. There was a warning about plugin information in the file (Corgi). Lets disable the plugin via Rhino 8>Settings>Plugins for testing purposes.
I turned off Corgi and upgraded to the latest candidate.
When I hit save there is no problem, but when I close the window and it tries to save I got the spinning beachball
However after restarting with corgi off everything seems to to be in order again. Thanks!
is there a reason to have Corgi?
If I remember correctly, Corgi was a tool for working with point clouds.
I never used it personally.
Out it goes then, it requested to be installed when I opened a grasshopper file…and I was hesitant to say no to loading it in case the recipe wouldn’t run properly.
thanks
Thanks for reporting this. I’ve been hearing other reports too. We’ll look into this…
RH-81891 Corgi package causes macOS Autosave hang requiring Force Quit
