Hi there,
would be possible to say Rhino will have all clipping section only in one master layer (as Make2D) with “Drawing/Hatch/Curve…” sublayers?
Or would be possible to have a preset option for sublayers properties for clipping section commnad (linetype, color, print width…)?
F.e.
- “all Curve sublayer are black, continuos, black print, width 0.35”
- “all Hatch sublayer are blue, continuos, grey print, width 0.2”
…and so on…
Rhino create for each clipping section separate layer with sublayers - if man have 10 or more section, then is terrible set up properties for each sublayer…
Choice “PrintWidth/DisplayColor=ByInputObject” isn’t solution…because need have Hatch properties and Curve properties in separete layers…
Second issue - in standard clipping plane and in clipping section too are visible lines behind “section plane” which should be invisible…(f.e. lines behind solids…)
