please see the steps in the brief video to help rerun the bug:
And mostly It would also crash when using “insert” command and the instances
This is very frustrating.
I see that you are using a command that doesn’t exist in my version of Rhino. Is this something that you can repeat using standard commands or is this related to a plug-in?
I can’t reproduce this behavior here.
You might want to provide code, a 3dm file, and the SystemInfo
data…
Hi @wim , I have retried after uninstalling the plugin and get the same result. Please have a check.
below is my systeminfo:
Rhino 8 SR13 2024-10-8 (Rhino 8, 8.13.24282.10001, Git hash:master @ 7fc2e504d4c838aa0264b02fb10e24ecfff2824a)
License type: Educational, build 2024-10-08
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-28-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4090 Laptop GPU (NVidia) Memory: 16GB, Driver date: 9-5-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 561.09
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-5-2024
Driver Version: 32.0.15.6109
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.4.0
C:\Users\weeke\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoFileVersion\7.0.8486\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.8486.27751
C:\Users\weeke\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\24.10.3.8\bullant.rhp “bullant” 24.10.3.8
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24282.10001
C:\Users\weeke\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24282.10001
Hi -
Thanks.
→ RH-84249 BlockManager: Crash When Docked
