RFQ 2 ea. main bevel gear and matching pinion bevel gear
Reaching out to bevel-gear-capable shops for quotes on a short run: 4 pcs. total.
2 identical sets of matching main and pinion straight bevel gears for a scale-model VTOL aircraft proof-of-concept prototype project. CAD models of the gears are currently available online in .3dm, .dwg, .dxf, .x_t, .stp and .step format.
If interested please reply with your email address and I’ll send a link to you to access the specs and files online.
Thanks in advance.
SD
PM sent, Please check.
Regards,
Trish
Thanks Trish.
Did you get the email with the link to the files I sent?
David Walden
Hello Trish,
I forgot to mention…all of the specifications including material are in “Bevel Gear README.txt” which can be found in the folder titled “Main Bevel Gear” at the link I provided in an earlier email.
Regards,
David
Hope you are doing well.
I can assist you with your requirement.
PM Sent
Plz Check!
