Revolve Problem
Hi, I am trying to make this decor revolve around the top of my arch. however i can only do it along the z axis when i want it on the y. How do i achieve this? I am playing around with where i place the revolve anchor point however this doesnt make a difference.
Hi Max, you could do it by revolve but here I would use sweep one rail - choose the edge of your arch then the shape (for a more exact fit, mirror your shape to the other side of the arch, then sweep then choose your shape one after the other)
HTH
Sweep1 as suggested by eleven is a good method for this.
Tu use the Revolve command you need to set the axis using two points. Turn on the Center Osnap and select the center of the arc as one point, then select another point away from the first point which is on the desired axis of rotation. (Setting the axis by selecting one point and then enter twice results in an axis parallel to the z-axis.)
