Revolve Points
Request - add points to curves as the type of objects which can be revolved using Revolve
I occassionally need to revolve a point around an axis to create an arc or a circle. Revolve with a point as the input is exactly the tool for this. However Revolve does not current accept a point as a type of object to revolve.
Current work-around:
Create a short line with the point at one end.
Revolve the line.
ExtractIsocurve or DupEdge to extract the arc or circle which passes throught he point.
Delete the short line and revolved surface.
Simple example:
RevolvePoint-DC01.3dm (2.1 MB)
revolve_points.py (1.1 KB)
edit: added undo
Thanks, but I’m requesting that the native Rhino command Revolve be enhanced with the addtion of points as objects which can be revolved.
right. but so far also extruding points does not work either without gumball. don´t keep your hopes up that this is going to find its way into Rhino very soon.
I hesitate on this feature.
from an academic point of view I like it.
from a educational / teacher’s / structural point of view:
_revolve is a surface creation tool, not a curve creation tool
if _revolve can handle Points, _extrudeCrv should handle them also.
I am not a big fan of making those basic / entry level commands more complex.
and I always think the question, if a feature is accessible via macro is a good question.
in this case
'_CPlane _3Point _Pause _Z _Pause _enter _circle 0 _pause _cplane _undo
my 2 cents: please keep _revolve a pure surface creation command
kind regards -tom
Hi David, I may be oversimplifying it but isn’t a point revolved a circle? I Must be missing something . —-Mark
correct.
Yes, a revolved point is a circle. My need is to create a circle with the circle passing through a specified point, the circle on a plane perpendicular to an axis/line, and the center of the circle on the axis/line. The center of the circle may or may not like between two points defining the axis/line.
In my first post I said:
@Tom_P This macro does not do what Revolve with a point would do. It does not create a circle with the circle passing through a specified point, the circle on a plane perpendicular to an axis/line, and the center of the circle on the axis/line. The center of the circle may or may not like between two points defining the axis/line.
Hi @davidcockey,
My first attempt:
RevolvePoint.py (7.4 KB)
– Dale
sorry i missed that the z-height of the circle center is defined by the point, not by the startpoint of the line / axis.
so i am in, but not for an option, but for a separate command
_revolvePt
best - tom
I’ve always thought it would be cool to think of lines/curves as points that travel through space/time :grinning_face: :clinking_beer_mugs:
I’m on board with this :100: :hot_beverage:
like a particle accelerator :slightly_smiling_face:
