This geometry, exported from Revit as ACIS Solids, is coming in as a single open polysrf. This seems invalid. Not unique - many other objects with the same error.
RevitToRhinoBug.3dm (58.9 KB)
Hi @ryan.odom,
It might be helpful for us to see the source file - the one exported from Revit.
– Dale
AWB WFS 2022_1_29.rvt (19.1 MB)
@dale - If you export this model with ACIS Solids and then run SelOpenPolySrf, you’ll fond a few of the misbehavers.
Hi @ryan.odom,
Opening the file in both AutoCAD 2022 and Rhino 7 yields pretty much the same thing. Running SelOpenPolySrf
in Rhino finds only 3 objects.
Perhaps I am missing something? There are a number of blocks. Do you see this too?
– Dale
@dale Forgot a step: I did use ExplodeBlock on everything first. You should see this once you explode blocks and isolate the open polysrfs.
