Revit Inside
Hi Daria, Welcome! I changed your forum topic to Rhino.Inside.Revit, the majority of GH users aren’t familiar with Revit or the plugin’s components.
When creating elements with Rhino.Inside.Revit (RiR) the elements are pinned. This allows for tracking and control from RiR, if you want to edit and break the relationship unpin the elements. If you can’t select, make sure you have Select Pinned Elements enabled in your Revit UI.
