Revit external tool failure (Rhino inside) Solution provided
Hello everyone ,
I’m trying to open Revit with rhino inside but Its shows this error when it load up. I got ss and shared with you. Please help me for fixing this problem.
Revit 2021
Hello there ,
I solved this problem. Now I’m explaining to you how I resolved it. Another plug in coincided with Rhino inside. Solution to the problem apply the following items ;
1.First, install the Stanted menager program on your computer.
2.Open the program and select your version of revit.
3.You will see the installed plug-ins. Turn off all plug ins and leave only rhino inside plug in active.
4.You’ll see the problem solved.Then activate all the individual plug-ins to determine which one they conflict with.
