Revit crashes as soon as I try to use "Add vertical Opening"
I am using Revit 2026 and Rhino 8.
When using the “Add vertical Opening” to create openings in a sloped roof, everything was working fine until recently.
I am no longer able to use the component as Revit crashes as soon as I plug my polyline, the same one that was working before, on the same host element.
Could it have to do with the component’s tracking ?
Any ideas on what could be causing the crash ?
Looks ok here, what is your RiR about info?
@ahmedwael.si My Revit is not crashing but I am getting sketch plane Error.
As an alternative you can use Add Shaft Opening
Here is my version :
In fact, the problem started when, after a crash, I first deleted the openings manually from Revit before launching Grasshopper,.
I don’t know if that may be the cause, but I am unable to add a single opening to my roof since then.
Are you creating opening in the sloped Roof or Flat Roof?
Sloped Roof
Shaft opening caused the same crash
Can you easily create the opening in the Flat Roof?
with sloped roof we have some limitattaions.
We dont experienece any crash.
I didn’t either, everything was working fine till recently when it started crashing.
Did you install any new Add-in?
Ok so using an older copy of both my .rvt project and my .gh script seems to work.
However, I don’t see what was causing the crash!
