Revit and Rhino compatibility issues
Good afternoon, I have an error with the compatibility of versions for Revit and Rhino Inside, where can I see some kind of summary table of compatibility between the plugin and Revit.
The topic about installing the plugin has a small table with links, but I have a problem in that the working project is in a different version than the current one. What should I do in this case?
Hi Владислав,
I changed your post to the Revit forum category.
You’ll want to update your Revit, there is a nasty schema bug that can permanently corrupt the Revit file, hence the requirement for the patched version.
Okay, thanks, is there some kind of compatibility table for Rhino Inside and Revit for different versions, so that we can review this for future projects?
Please see the release notes for specifics. Rhino.Inside®.Revit
I’ll adjust the Rhino.Inside®.Revit page you referenced to a include Revit 2025 and 2026 as well as add a table for Rhino 7/8/9 compatibilities with each Revit Version.
Thank you very much, I’ll look at the information there now.
