Revision balloon?
Was reworking something and instinctively went to where my Revision balloon icon sits in AutoCAD. I couldn’t find a similar tool. For those drafting in Rhino, what do you do in such a case?
RevCloud
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/revcloud.htm#(null)
We do our drawings on layout tabs with detail views in Pen mode. Much like John says, we use RevCloud (specifically, I draw a box around the revised item, and use the “Curve” option in RevCloud, dividing by whatever seems appropriate). Then for the revision triangle “bubble” I drop in a pre-made group from our drafting template, with the triangle and letter already in place. Then I edit the letter.
(I’m actually looking at eventually updating the revision triangle to be a block that pulls from document data, so I can stop editing the revision callouts manually!)
