Returning a list in a custom GH component
Hello there, I’m new to Grasshopper and I’m trying to create a custom component using visual studio that calculates the intersection between two objects, and returns the points where said objects intersect. This works fine when I return a single point of intersection.
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
            pManager.AddMeshParameter("Mesh", "M", "Mesh to use", GH_ParamAccess.item);
            pManager.AddLineParameter("Line", "L", "Line to intersect", GH_ParamAccess.item);
        protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
            pManager.AddPointParameter("Intersection", "I", "Point of Intersection", GH_ParamAccess.item);
        protected override void SolveInstance(IGH_DataAccess DA)
            Mesh mesh1 = new Mesh();
            Line line1 = Line.Unset;
            if (!DA.GetData(0, ref mesh1)) return;
            if (!DA.GetData(1, ref line1)) return;
            Point3d[] intersections = Rhino.Geometry.Intersect.Intersection.MeshLine(mesh1, line1);
            Point3d inter = intersections[0];
            DA.SetData(0, result);
This way it works, however, if I wnat to return instead of one point, a list of points (because there is more than 1 intersection) it wont work. This is the code
            pManager.AddPointParameter("Intersection", "I", "Point of Intersection", GH_ParamAccess.list);
            List<Point3d> result = new List<Point3d>();
            foreach (Point3d p in intersections)
                result.Add(p);
When I run this I get this error
What am I doing wrong? I know it can be done with list of numbers but i cant make it work with objects
Hi
Use DA.SetDataList(intersections).
            DA.SetDataList(0, intersections);
Hi, it works, thank you very much!
